Tpsm sytem fault 08 jag
Old Oct 5, 2018 | 08:03 PM
Jdel's Avatar
Default Tpsm sytem fault 08 jag
i had a flat tire. Drove few minutes with the flat
and i notived this code at my dashboard. My
tire was completly destroyed. I bought a
new tire and also put a new valve sensor
on that tire. The guy at the tire shop check
every single tire with a computer and all
appears to be fine. Code was erase and kept
poping back. Anyone can advice me?
Old Oct 5, 2018 | 08:51 PM
Dell Gailey's Avatar
Never seen an X Type (X400) with TPMS.
Old Oct 5, 2018 | 10:54 PM
greenestate's Avatar
TPMS was only offered on 2008-9 X-types here in the UK ......dont know about the US...you guys seem to get more options before us.
If they're the same as the ford system then as long as the sensors all linked up ok when the guy fitted the new one.
the system should 'reset' its self after you've driven for a few mins.
If it the tpms fault wont clear it sounds like the new sensor may not have been of OEM quality ..after all I assume the 1 wheel is all that's been touched...so you have to look back at the one bit that's been changed.
Old Oct 6, 2018 | 04:09 PM
Odd, I seen a boat load of posts in the xf and xk forum about troubleshooting this problem. Antennae, sensor, wiring, deflation of all 4 tires to 15 p.s.i. Then reinflating to correct pressure, then driving to reset, etc. You might get some leads reading those.
Old Oct 8, 2018 | 04:34 PM
Jdel's Avatar
the sensor was programmed and its 315 mz..I think the
problem it's something else. Someone e told me to go to the fuse box and pulled fuse F2 for a minute
and module would reset
PA_JAG_GUY
Oct 23, 2017 09:44 AM
rinaldi63
Oct 27, 2010 10:52 PM
acab1120
Mar 5, 2010 11:45 AM
stefon
Nov 22, 2007 01:52 PM
