tranny question
Old Apr 6, 2008 | 12:00 PM
billinohio's Avatar
Default tranny question
how hard is it to adjust the tranny cable? mine won't go into low on the left side of shifter. thanks, Bill
Old Apr 6, 2008 | 02:28 PM
aquill1's Avatar
Default RE: tranny question
Help will be by shortly...sorry i couldn't help...
Old Apr 6, 2008 | 07:30 PM
Dennis's Avatar
ud
Hi Bill..What do you mean "won't go into Low"?..You mean the 2nd gear spot? or any of the speeds on the left side of the J-gate?
Old Apr 6, 2008 | 08:09 PM
FactoryJaguarTech's Avatar
First off, remove the wood surround and the center console. Loosen up the 4 bolts at base of shifter then put would back on. Tighten down the 4 bolts and put it back together. If still not right it needs to be adjusted from underneath and thatis a little more tricky.
Need more info on your problem first though.
Old Apr 6, 2008 | 11:59 PM
billinohio's Avatar
when i put the shifter over on the left side of j-gate it only has 2 gears to shift through, it feells like the low and drive work but no real "shift" had same problem years ago and it was the cable catching on the side of the console.
Old Apr 7, 2008 | 10:13 AM
aquill1's Avatar
You try taking it apart yet? It's really easy to get at if not...
Old Apr 7, 2008 | 12:27 PM
aquill1's Avatar
Video won't work with my computer/internet speed for right now...the file was like 30mb so email might be out of the question...aim allows large file transfers though...otherwise here's the linky...
Old Apr 7, 2008 | 12:31 PM
billinohio's Avatar
said it was unavailable
Old Apr 7, 2008 | 12:37 PM
aquill1's Avatar
wouldn't work for me either...starts buffering and than that's it...hmmm...do you have aim (aol instant messenger?) They limit what can be sent on email and I didn't realize until after that it was too big...actually I'm going to play it on my computer and than record it with my cell phone....one sec...
Old Apr 7, 2008 | 12:42 PM
billinohio's Avatar
thanks, no i dont have aim. could probably make up an email quick enough
Old Apr 7, 2008 | 12:52 PM
aquill1's Avatar
recorded on webcam quality sucks...i'm gonna try youtube...one sec...
Old Apr 7, 2008 | 01:05 PM
billinohio's Avatar
you frickin rock!
Old Apr 7, 2008 | 01:06 PM
aquill1's Avatar
I just tried youtube for over 10minutes and that video is too big I assume. I'm going to go take it again on my cell phone instead and see what happens, you'll get the idea...
Old Apr 7, 2008 | 01:08 PM
billinohio's Avatar
man what a guy!!!!!!!!!!!!!!! and an awesome mod to boot!!!!!!!!!
Old Apr 7, 2008 | 01:24 PM
aquill1's Avatar
hey bill try that first video I sent again...i just took and uploaded the one on my camera phone and it sucks but it's not working just like the other one...but now it's working...
http://picasaweb.google.com/aquill1/...52447647535586
Old Apr 7, 2008 | 01:25 PM
aquill1's Avatar
Thanks btw!
Old Apr 7, 2008 | 01:31 PM
billinohio's Avatar
that worked great. will try it out!!!!!!!1 thanks, Bill
Old Apr 7, 2008 | 01:35 PM
aquill1's Avatar
Let us know, you'll need a star bit or you can also use an allen wrench to get the 4 bolts out but be careful...don't wanna scratch it up!
Old Apr 7, 2008 | 02:06 PM
Nice vid bud. The bolts you are showing are 20 torx bolts. You need to remove the wood as you did, then the carpet at the sides of console.....one phillips screw holding each side in then you just pull. At the base of the J-Gate, where it bolts to the floor, there is 4 10mm bolts holding it down. Loosen them up put the wood back on to line up the shifter. Keep it in neutral while doing this. Once wood back on tighten down the 10s and replace the side panels of console. Likely though you have a cable problem at trans.
Old Apr 7, 2008 | 02:23 PM
aquill1's Avatar
Yeah what he said...
