Trying to diagnose an issue
Old Jul 20, 2022 | 05:03 PM
GunganGundam's Avatar
Default Trying to diagnose an issue
Hello everyone,
Trying to diagnose what's wrong with my 2006 3.0 X type. Sometimes I get a slow start (have to keep the key turned for a good few seconds). and twice in the past three months the car stalled during normal driving, killing power steering/brakes, if I pull off to the side of the road, put the car in park it then starts right back up like nothing happened. I've heard it could be the crankshaft sensor? if anyone's faced a similar issue I'ld love to know.
Old Jul 20, 2022 | 05:23 PM
Dell Gailey's Avatar
Could be many things. Get an ELM327 and pull the OBD codes. Either post them back here or the SMART way, look them up in SEARCH (a MARVELOUS TOOL).
That being said, I wager a nickle fuel pump dying.
Old Jul 20, 2022 | 11:32 PM
I had the fuel pump replaced just a year or two ago so it better not be that, only trouble I'm seeing after checking codes is an intake air temp sensor circuit intermittent high voltage
Old Jul 21, 2022 | 03:03 AM
The symptoms certainly indicate a temperature sensor (ECT, EFT or IAT) fault is a possibility.
When referring to error codes, always post the actual code(s) and not just the descriptions. Generic code lookups are frequently misleading and the Jaguar DTC lookup should be used.
File Type: pdf
Old Jul 21, 2022 | 03:46 AM
Signs Your Cylinder Head Temperature Sensor Needs to be Replaced
  • Extended cranking time when trying to start your vehicle.
  • Decrease in fuel economy.
  • Decrease in acceleration.
  • Check engine light comes on.
  • Your vehicle jumps when you accelerate.
Bad Intake Air Temperature Sensor (IAT) Symptoms
  • Check Engine Light. The check engine light will often appear on your dashboard when you have any issues with the IAT sensor. ...
  • Drop in Acceleration. ...
  • Hard Cold Start Condition. ...
  • Rough Idle. ...
  • Misfires. ...
  • EGR Valve Affected. ...
  • Poor Fuel Economy
JaguarXKR
Aug 20, 2022 05:58 AM
novium
Dec 4, 2021 07:32 AM
chazaroo
Aug 17, 2012 11:39 AM
