Type of Fuses in Fuse Boxes
Old Dec 9, 2024 | 05:00 PM
captbob73's Avatar
Default Type of Fuses in Fuse Boxes
After a few years, I must replace some fuses in the Passenger Fuse Box of my X-Type Wagon.
Thought this would be a no-brainer. Went to Auto Zone and was confronted by several sizes of two-blade fuses. I quickly went to Google for an answer, and was informed that the X-Type uses an ATO/ATC fuse. That appears not to be correct. They look too big.
Would appreciate any help in determining what type 2 blade fuse is used in the X-Type fuse boxes. I would like to buy some 10A, 15A, and 30A fuses.
Thank you,
Old Dec 9, 2024 | 05:39 PM
Dell Gailey's Avatar
You need micro blade fuses. I get mine from temu or Amazon, way, way less money...
Old Dec 10, 2024 | 06:08 AM
captbob73's Avatar
Thank you. I had guessed 'mini' but I need to go smaller.
Old Dec 11, 2024 | 12:36 PM
captbob73's Avatar
I purchased some micro fuses. However, when I compared the micro fuse to the fuse taken from my interior fuse box, the micro fuse was too small. The fuse I removed from the fuse box measures 5/8" long and 3/8" (maybe 7/16") wide. Not sure what those measurements equate to in the world of car fuses. That said, I am amassing a large collection of fuses.
Old Dec 11, 2024 | 05:58 PM
Thermo's Avatar
Veteran: Navy
ATC fuses come in a few sizes. You have normal, miniature, micro, and maxi. Our cars use a few different sizes. So, you will need to pretty much pull the fuse in question when at the auto parts store and match up the sizes.
Old Dec 12, 2024 | 04:05 PM
cat_as_trophy's Avatar
+1 to what Chris says. I buy mine in a plastic box of 300 plus 2x pullers.
That's 100 of each 0f 3 commonest sizes Chris notes . . . standard, mini, micro.
I note also that in smaller format, there are 2 different types . . .
  • 1st with just end-exposed blades;
  • 2nd with edge shoulders of blades exposed also
I buy direct from China . . . box of 300 for about AU10
That's about US$6, or 2c each! and includes plastic parts box and free shipping!
Cheers,
Old Dec 13, 2024 | 06:06 AM
captbob73's Avatar
Thank you, both.
Appears I need to remain flexible and own a number of fuse types.
Old Dec 14, 2024 | 01:15 PM
DaveAllen's Avatar
FWIW I bought a couple of used fuse boxes on Ebay for the X-Type and XK8. They came loaded with fuses and relays - all OEM. I tested the fuses and relays - all good (didn't need the actual fuse boxes). For about $40 I've got a lifetime of OEM spare fuses and relays.
HTH, Dave
Old Dec 15, 2024 | 06:33 AM
captbob73's Avatar
Dave -
That's a clever solution. Thank you.
Svalbard
Oct 12, 2025 06:12 AM
Tippo
Apr 1, 2022 05:45 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
frederikv12beauty
Aug 8, 2010 08:20 AM
boydy70
Mar 4, 2010 07:54 PM
