Upper Radiator hose, thermostat housing
Old Aug 11, 2013 | 07:46 PM
akubeta's Avatar
Default Upper Radiator hose, thermostat housing
I am in the middle of replacing my Upper Radiator hose (X-type 2002), when I got stuck trying to remove the 13mm nut for the thermostat housing, it is in an awkward position. and I can't seem to get it out. Are there any tricks or tips on removing it?
Old Aug 11, 2013 | 10:31 PM
cujet's Avatar
I just changed mine. Ended up using a combination of tools to do the job.
The end result was that a 3 inch extension and a thin wall socket was needed for the one that's impossible to touch.
Once loose, I used just the extension and socket between my fingers to unscrew it.
Wahooesprit
Dec 23, 2019 02:01 PM
Philurusso
Sep 20, 2015 07:02 AM
Tipptone
Sep 16, 2015 07:39 AM
1964Daimler
Sep 9, 2015 11:28 AM
