Which Volvo gearbox?
Old Dec 12, 2021 | 01:19 AM
Xtypehaxor's Avatar
Default Which Volvo gearbox?
Supercharged x400 prototype
any idea which gearbox was used?
Any idea what other changes were made?
it seems easy enough to add a turbo and build a custom controller and anyone with a cnc mill can build a strengthened transfer case. It just might be simpler to use an existing Volvo transmission from a junked car.
Old Dec 12, 2021 | 09:17 AM
Thermo's Avatar
Veteran: Navy
Considering that some parts are shared between the S40 and the X-TYpe, I would start there and see what you can find out. Much beyond that, you are having to look at bolt patterns and shaft splines to see what may or may not work.
Old Dec 12, 2021 | 08:47 PM
Dell Gailey's Avatar
The 5 speed automatic transmission in the S40 is a 5-speed Aisin AW55-50. Not a Jatco.
JATCO Ltd (Japanese: ジヤトコ株式会社, Hepburn: Jatoko Kabushiki-gaisha), abbreviated from "Japan Automatic Transmission COmpany"
Aisin is a member of the Toyota Group of companies.
Old Dec 14, 2021 | 03:27 AM
Panthro's Avatar
The 2008 FWD X-Type used the Aisin 6-speed, but since it was a prototype, I'd actually be surprised if it wasn't a manual transmission. Much easier to experiment with, programming-wise. Why not send a PM to Count Iblis & see if he remembers anything
Old Dec 17, 2021 | 02:32 PM
xalty's Avatar
M66
cryptokayn
Dec 4, 2021 08:23 PM
Chris Steineger
XK120 XK140 XK150
Jun 29, 2018 04:10 PM
mpsa
XK120 XK140 XK150
Jan 28, 2018 02:25 PM
Will R
E type ( XK-E )
Oct 26, 2015 08:22 AM
