Were is the AC drain????????
My wife's Jag is starting to have a musty smell and I just went out to check it after she got home and no water under the car. So, I think the drain is clogged. Were is it so I can clean it out an is there any special way to do it?
I replaced that wiper motor three weeks ago and the filter did not look dirty. I did not remove it but, it looked clean. I'm sure the water drain for the AC is clogged, I just don't know were it is. After my wife parked the car when she got home from work (which was a 30 min ride with the AC on in 90 deg heat) there was no water under her car. The only way a car would have a musty smell is stagnant water..
[QUOTE=slickman;61857]No need, I found what I needed on jagbits, the tube is coming down from the firewall and is right over the exhaust.[/Q
my daughter owns 2005 x type. I was trying to find this drain tube. any picture?
thank you
thank you
