What is this part?
Old Jul 22, 2018 | 06:29 AM
jgonzalez2002's Avatar
Default What is this part?
Hello, I am new on this goruf and on the DIY... I took my 2002 X-type for a degrease engine job and have noticed a small oil leak from here (picture)... what is the name of the part? I assume that I need to replace it or is there something else going on (e.g. execce oil)?
Old Jul 22, 2018 | 07:29 AM
Thermo's Avatar
Veteran: Navy
That would be the camshaft sensor. if it is leaking oil, then odds are you simply need to remove the valve cover and put on a set of new seals. There should be a rubber "o-ring" on it that forms a seal. That is going to be a lot easier and cheaper than buying a new sensor since you should have a new seal set when you replace the sensor any ways.
Old Jul 22, 2018 | 07:58 AM
dwclapp's Avatar
jgonzalez: I presume the oil leak is very minimal, since there's no oil pressure inside the valve cover, and oil must flow uphill to leak out at that point. Thermo's right - the permanent solution is replacing the rubber seal around the camshaft position sensor, which involves removing the valve cover. As an interim fix, without having to remove the valve cover, you could try a dab of RTV Silicone on the rubber seal where the oil is seeping out.
Old Jul 22, 2018 | 03:24 PM
Default Thank you both
Old Jul 22, 2018 | 04:28 PM
astromorg's Avatar
Mmm! Slip of the memory there I think Thermo! It's the left hand Variable Camshaft Timing Control Solenoid Another one on the right hand bank.
The leakage rate at this v low pressure position is so little, it questions the worth of removing the cambox to do the job. A weekly wipe works wonders!!
Old Jul 22, 2018 | 05:30 PM
Thermo's Avatar
Veteran: Navy
Astromag, you are correct. had to look to check myself. Either way, the solution is the same, pull the valve cover and replace the rubber seal around the solenoid.
Old Jul 23, 2018 | 05:05 PM
Dell Gailey's Avatar
Astro. You only wipe weekly? OK, today I'm a bit off kilter, soz.
Old Jul 24, 2018 | 01:17 PM
astromorg's Avatar
At my age I'm lucky if it's weekly.
qwiketz
Mar 22, 2012 10:30 AM
pdog2000
Oct 11, 2011 05:54 AM
sam2007
Mar 22, 2011 04:42 AM
H20boy
Jan 18, 2011 08:54 PM
