wheel offset
Old May 20, 2007 | 09:24 PM
Cam99's Avatar
Default wheel offset
What is the offset for X-type wheels. I'm looking at aftermarket and other than bolt pattern I'm not sure what to look for.
Old May 21, 2007 | 04:34 AM
racerx82's Avatar
Default RE: wheel offset
45-48 i think
Old May 21, 2007 | 10:37 AM
bigdreams05's Avatar
Uhhh, insult to injury. Once again he comes, answers to the newbies, and leaves. BTW, I'd stay at around a 40+or-3 just to be safe!
Old May 21, 2007 | 11:35 PM
SonicRiot's Avatar
The bolt pattern is 5X108 and the offset is somewhere around 40mm on both X and Taurus, but the centerbore of the X is 63.6 and the centerbore of the Taurus is 63.9. So, technically, they are not the same fit. 3mm may not sound like a lot, but it could cause some weird mounting issues and potentially cause vibrations.
Old May 2, 2010 | 06:45 AM
Sandro's Avatar
I am resurrecting this old thread I found as I was searching for this information.
Not to beat a dead horse but... what is the offset of a OE 16 x 6.5 ?
The posts of this three-year old taken together give a range of 37-48 mm
I was wondering if three years later the consensus has perhaps narrowed to a single figure, as it should be.
I have searched everywhere I reasonably could and have not found this information yet...
- Sandro
Old May 3, 2010 | 08:29 AM
MarkC's Avatar
The offset of the stock 16x6.5 wheels is 52.5 mm....stamped on the wheel.
Old May 3, 2010 | 12:09 PM
Sandro's Avatar
Thanks a lot!
I am planning on getting some gripper summer shoes for my "new" X.
225/50/16 upsize would give the same gearing as the OE 205/55/16 --- same 25.9" diameter --- but have more footprint with no much weight penalty.
The stock 6.5" rim would be too tight for this tire width though. TireRack carries some relatively light (17.5 lb) inexpensive 16 x 7.5 rims with 50mm offset
http://www.tirerack.com/wheels/Wheel...&wheelModel=F7
Starting from the OE 52.5 OE offset, a 7.5" wide rim with 50 mm offset would stick out an extra 15 mm outside and 11 mm inside.
Would I have any interference/clearence problem with that? I don't think so but wanted to double check, I am at work now and cannot take direct measurements...
Thanks.
- Sandro
Old May 3, 2010 | 12:13 PM
jonre's Avatar
thats what mine says!
H20boy
Dec 24, 2024 03:23 PM
Forcedair1
Feb 19, 2020 01:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
DustysSon
Sep 13, 2015 04:17 AM
ferraripete
Sep 10, 2015 01:24 AM
