x type demister
Old Nov 23, 2018 | 01:47 PM
AndyT's Avatar
Default x type demister
I,m having problems getting hot air to blow onto the windscreen on my x type. I can get some air out on demist setting enough to clear the screen but have to drive around on demist all time so can't get hot air to other vents. Just pressing the button to send air to screen/feet I get nothing. Using AC set to auto doesn't mist up to bad but still a bit. This is more annoying than anything else but I would like to fix it if possible because it is annoying me.
Have changed pollen filter which was bunged up with lots of crud. AC/heating is of push button variety not any other form of climate control that may of been fitted to other models.
I am assuming that something is stuck or a motor is not working, have tried some sort of reset procedure shown on forums involving full heat, full cold, blow air here, there etc and not worked.
I need to know what to look at, where it is and if I can get to it without to much hassle.
Any help would be much appreciated, Andy.
Old Nov 23, 2018 | 04:36 PM
DUNKS's Avatar
Pleased to see you have asked this. My X type suffers the same.
Someone must have the answer.
Old Nov 23, 2018 | 05:25 PM
Dell Gailey's Avatar
Actuators a.k.a. Stepper motors or the "rods". Do a search here, lots of info including a seldom successful "stepper motor reset".
Example of searching =
https://www.jaguarforums.com/forum/x...r-95548/page2/
Old Nov 24, 2018 | 03:51 AM
DUNKS's Avatar
Thanks. I see what is required for a fix and think I will put up with the problem. A short blast of the demist button always clears the screen.
jimp6688
May 8, 2020 11:30 AM
K.Westra
May 6, 2020 11:22 AM
abonano
Mar 25, 2017 09:19 PM
cbodman
Nov 9, 2013 03:30 PM
maxthrottle
Jan 9, 2011 04:30 PM
