X type heated seat swap
wahooespirit, yes, you should be able to switch between the two cars. You may need to get into the module and tell it what seat it has, but after that, the module should handle the seat with no issues. With that being said, you may also have to upgrade the wiring between the driver's seat control module and the seats if you are adding additional features. Check the plugs and see if they are the same. If so, then you are good to go other than the module programming. If not, you may have to borrow wiring from one car and put it in the other.
fayho
Oct 3, 2014 10:45 AM
