x type and light on dash
Old Dec 28, 2008 | 04:40 PM
Brutal's Avatar
Default RE: x type and light on dash
On the Xtype its almost always bad battery cables, most notably the positive has too much resistance from the alternator to the battery. If you use a digitsal volt ohm meter and measure the voltage at the battery posts, and then at the postive cable on the back of the alternator you'll find there's usually more than .10 volts or more difference between the 2 and you need a new postive cable. Oh, that light meens there not the correct voltage to the battery
stanjag
Dec 29, 2024 08:26 PM
gene1
Aug 27, 2015 08:56 PM
stetson1
Aug 27, 2015 07:49 AM
divingmom
Aug 25, 2015 07:54 PM
