xtype cuts out
Old Oct 15, 2016 | 04:01 AM
daviejon's Avatar
Default xtype cuts out
Hi I have a problem with my 2004 xtype when I change down in to second gear and turn in to a street the car displays the glow plug light and the car loses power coming to a stop I can restart the car
what I have done at the moment is to remove the egr valve and cleaned it out then I removed the inlet manifold and clean that out too I have cleaned out the turbo too I fitted a new air filter as that was very dirty
next was to fit a new gray camshaft position sensor and it run fine for 2 days
then it happened again
turn in to my street and it displayed the glow plug light?
any suggestion to this problem would be appreciated
Old Oct 15, 2016 | 07:51 AM
swingwing's Avatar
I have never worked on a diesel engine (never owned one), but it sounds to me like you've got a fuel delivery problem. When's last time you changed the fuel filter? I see the Jaguar part number as C2S27643.
Old Oct 15, 2016 | 09:46 AM
daviejon's Avatar
Hi yes it could be that, it is alright while it is running normal it is when I slow down change into second gear and go around a corner thats when glow plug light comes on and it cuts the power it does not go into limp mode and it starts up straight away no problems?
so many people out there giving different answers to the same problem?
Old Oct 15, 2016 | 04:38 PM
swingwing's Avatar
I'm not sure of the recommended service interval for the fuel filter; you might ask around. If yours had some debris in it, higher rpm from the downshift and turning might be enough to restrict fuel flow. Cost of a new filter shouldn't be too dear and fairly easy to replace; I think it'd be a reasonable try.
Old Oct 16, 2016 | 03:29 AM
daviejon's Avatar
I am going to fit one tomorrow will let you know how it goes on
thank you Swingwing
Old Oct 17, 2016 | 02:53 AM
joesoap's Avatar
What about DTC codes- you are pissing in the wind without this info?
By all means fit a new filter, going by your description of air filter it probably hasn't been changed before?
What is Mileage on car, there are a lot of issues re fuel pumps and injectors with early 2.0d.
jakesdad
19
Sep 9, 2016 04:24 AM
detonator
Sep 4, 2016 09:57 AM
NiteriderSC
Sep 2, 2016 03:14 PM
Brandon Wright
Aug 27, 2016 05:06 PM
ShaunPA
Aug 27, 2016 07:15 AM
