XE ( X760 ) 2015 -
Fuse location indicators XE
Old May 30, 2022 | 04:50 PM
Bpba's Avatar
Default Fuse location indicators XE
Can anyone tell me where are the fuse is for the indicators on jaguar xe
Old May 31, 2022 | 05:06 AM
2018XF25T's Avatar
Hello,
I don't have an XE but the link below will guide you through where to look at. On the website it give you the info. Click on RELATED INFORMATION. Also, consult your owner's manual. On the fuse cover, there are fuse markings & indications. Good luck
https://www.ownerinfo.jaguar.com/doc.../proc/G1878559
Old May 31, 2022 | 06:04 AM
Bpba's Avatar
Thank you cannot find there thanks again
Old May 31, 2022 | 01:21 PM
There isn't one.
Exterior lighting, including the indicators and hazard warning lamps, is controlled by the BCM / GWM (Body Control Module / Gateway Module) which is connected to the Medium Speed (MS) and High Speed (HS) Controller Area Network (CAN) buses.
All exterior lighting circuits are protected by Field Effect Transistors (FET's) in the BCM / GWM which can detect overloads and short circuits. The FET's respond to heat generated by increased current flow caused by a short circuit. On a normal (fused) circuit this would cause the relevant fuse to blow but the FET's respond to the heat increase and disconnect the supply to the affected circuit. When the fault is rectified or the FET has cooled, the FET resets and operate the circuit normally. If the fault persists the FET cycles, disconnecting and reconnecting the power supply.
The BCM / GWM stores fault codes which can be retrieved using Jaguar diagnostics to help in troubleshooting.
leadfoot4
XE ( X760 )
Sep 11, 2021 06:13 AM
tferrari
XE ( X760 )
Mar 24, 2021 04:43 PM
Matrixpt
XE ( X760 )
Nov 23, 2016 02:12 PM
Jayt2
XE ( X760 )
May 13, 2016 03:04 PM
