XE ( X760 ) 2015 -
Jaguar XE 2016 Model - Exhaust Vibrations / Balancer / Dampener - Question
Old Aug 24, 2020 | 07:15 AM
JaguarXECrappy's Avatar
Post Jaguar XE 2016 Model - Exhaust Vibrations / Balancer / Dampener - Question
Hi
First time posting, sorry if wrong section. Have a query on labour required for a specific job.
The exhaust has been rattling and vibrating like a Y reg van. I've checked and the rubber exhaust damper at the rear is broken. This part:
Is it straight forward... unscrew and re-screw or does it latch onto something on the inside of the exhaust?
Got a quote for £95 from Jaguar but if the piece is £20 and it's just a straight unscrew/screw I'll do it.
Cheers for the assistance.
Old Aug 25, 2021 | 11:56 AM
johnsim213's Avatar
Originally Posted by JaguarXECrappy
Hi
I did this job today part was £35 from Taggarts Jaguar in Glasgow, 5 minute job, it fixes straight to exhaust so no alignment issues. You can get at it from rear of car no access issue either - only problem I had was a new vibration at idle - solved that by using old bolt which is a slightly different shape from the new one supplied. Hope this helps
ebolt
XE ( X760 )
Aug 1, 2023 10:55 PM
supraken
XF (X260)
Jan 8, 2021 10:44 PM
Scouse Submariner 1878
General Tech Help
Apr 14, 2020 09:02 AM
Jaguar Forums Editor
XE ( X760 )
May 18, 2016 04:29 PM
spectremotorsports
XE ( X760 )
Jan 8, 2015 01:19 PM
