XE ( X760 ) 2015 -
Jaguar XE no ign
Old Apr 20, 2026 | 01:23 AM
DOCKERS's Avatar
Default Jaguar XE no ign
I have a Jaguar XE 2017 and I have no communication with RFA and due to this I cannot turn on ign. I tried to write virgin data to bcm and even after then I cannot communicate with rfa or any other modules. I can communicate only with BCM IPC ABS modules. I have attached the DTC here in mail. Can anyone help me with this issue? I guess it need some bcm config in order for other modules to communicate.
Old Apr 20, 2026 | 07:48 AM
RoverJoe's Avatar
Community Influencer
Have you checked the power/ground/CAN at the RFA? It's possible the module just failed. Not sure what operation you ran on the BCM but that doesn't sound like it was a good idea. A failed RFA will not be fixed by configuration issues in the BCM, and rewriting a BCM with other theft relevant modules off the network could lock it up as well.
Luc Lapierre
Sep 3, 2024 11:24 PM
tycol
XE ( X760 )
Oct 22, 2019 07:52 PM
Matrixpt
XE ( X760 )
Nov 23, 2016 02:12 PM
Jaguar Forums Editor
XE ( X760 )
Aug 15, 2016 06:20 PM
Eurobahn Jaguar
XE ( X760 )
Jun 28, 2016 10:41 AM
