XE ( X760 ) 2015 -
Rear Shock Replacement Advice
Old Sep 19, 2023 | 03:38 PM
OnecoldXe's Avatar
Default Rear Shock Replacement Advice
Hey All,
Took my 2017 Jaguar XE 35t R-Sport into the dealer for service today. They noted one of the rear shocks was leaking and required replacement. Quote for both rear shocks came in at over $2,400 CAD as this doesn`t fall under the extended CPO warranty. This seems like a lot, even for our vehicles, can anyone confirm? I am having trouble sourcing any aftermarket replacement options as well. Has anyone had luck replacing with aftermarket or sourcing a reasonable OE source in Canada?
Thanks!
Old Sep 20, 2023 | 06:28 AM
chrisjp's Avatar
I also have had a badly leaking rear shock absorber on my MY20 XE 2.0L and it seems to be quite a common fault.
Like you the dealer refused to replace it under warranty, so I did the job myself - it's just 3 bolts to remove and then swap the top mounting from the old one to the new one.
I did have a bit of difficulty sourcing a new shock absorber from anyone by Jaguar, but eventually found a supplier at £182 - David Manners in the UK ((www.davidmannersgroup.co.uk)
They might be willing to export to Canada.
Old Sep 20, 2023 | 07:19 AM
OnecoldXe's Avatar
I didn`t see a dropdown menu for the XE but I sent them a message. Thanks!
doghead08
Aug 25, 2023 04:51 PM
KT907
Aug 17, 2023 10:33 PM
Armand
Feb 3, 2023 06:30 AM
RealtorMPG
Jul 30, 2013 08:37 AM
