XE ( X760 ) 2015 -
A side exterior mirror replacement advice
Old Sep 29, 2018 | 10:14 PM
EngshMan's Avatar
Default Side exterior mirror replacement advice
Does anyone know the best website where I can get a replacement mirror glass for the 2017 Premium? It has an auto dim and heated. Also, tried to register on Topix to get a diagram and replacement process, but everything is a premium content. I found one part C2Z31945 but it doesnt have an auto dim and power fold.
Old Sep 30, 2018 | 09:30 AM
BritCars's Avatar
I've used the JLR dealer called Merriam Parts online a number of times. They have a fully searchable online jag parts list by car model, you can see all the diagrams to choose the right part. And they seem to run at 10-20pc discount off the normal jag price
If you give them your VIN they will confirm you have the right part
Old Oct 9, 2018 | 01:22 PM
As I'm driving a 2018 XE this week as a courtesy car whilst my XK is in for warranty work, I've made a rare stop here.
TOPIx is a subscription service aimed at Jaguar Dealers but available to anyone prepared to pay - by the hour, day, week, month or year. It is possible to purchase 1 hour of access and download the entire Workshop Manual for your vehicle in that time but this is overkill for a mirror glass replacement.
The procedure is pretty much standard across the model ranges .........
Your first problem is identifying the correct Part Number. As this extract from JEPC (Jaguar Electronic Parts Catalogue) shows, there is a remarkable array of options for the X760:
Your second problem is likely to be the need for medical intervention when you find out how much it is.
Old Feb 2, 2019 | 12:59 PM
EngshMan's Avatar
Changed it without a workshop guide, but appreciate a lot for your effort to help. I purchased a replacement much more cheaper than it retails and turnout it's the same part number fits the XF model this made a trick saving some $. It took me about 10 minutes to replace an old one if I knew I could push it further possibly it would take less time since I needed neatly disconnect the wires and one has a clip.
jaguny
Nov 22, 2014 09:13 AM
boddek
Mar 27, 2013 07:14 AM
ojai03
Nov 21, 2012 01:06 PM
billrus
Jun 23, 2011 04:11 PM
stephen11962
Aug 3, 2010 08:38 PM
