XE ( X760 ) 2015 -
Transmission Fluid change 2017 3.5 awd 3.5t awd
Old Jan 16, 2023 | 11:10 PM
Rodgerrabbit's Avatar
Default Transmission Fluid change 2017 3.5 awd 3.5t awd
What mileage and how ?
Old Jan 18, 2023 | 11:53 PM
90,000 miles .I'm thinking I pull the shield and then remove the pan with the built in filter . Let it drain a bit and then install new pan and fill with appropriate atf oil
Old Jan 21, 2023 | 11:55 AM
Any transmission shop recommendations in the Portland /Vancouver area? 600 $ seems a little steep !
Old Aug 21, 2023 | 07:26 AM
SJones's Avatar
Honolulu can be a mixed bag as far as environment the car was kept in. If it lived on the windward side of the island, it would be exposed to high humidity and salt air, on the leeward side mostly dry. Garages are not on a high percentage of houses, carports are more common. Speed limits are relatively low with lots of cops everywhere to ensure a ready stream of revenue in the form of speeding tickets. The roads are generally in poor condition so expect lots of gravel abrasion in the front and rear flanks if not covered with Xpel. I lived on island for four years with my Lotus Elise, the dealer who was also the Jag dealer was expensive but pretty good
Old Jul 16, 2024 | 11:29 PM
dougsz28's Avatar
I have a 2017 XE 35T V6, after 8 years I thought it would be a good idea to flush out the old stuff and put in new fluid. Went to the ***********, he had not parts
and would have to order it. Yes, you do have to replace the pan as the filter is an integral part of the pan. I was quoted $1800 for the part plus fluid and install.
How does that grab ya? To say the least I just about crapped my pants. I asked if you just couldnt remove the pan and backflush the filter and clean the pan.
Well he said no go, it would leak! My thinking is BS. I think they just want to sell parts! Anyone else have any experience with this?????
Old Jul 17, 2024 | 01:15 AM
dangoesfast's Avatar
My understanding is the filter and pan are one unit so should be replaced together, don't skimp on that.
It cost me about 400-500 Australian dollars to have my transmission drained and filled with a new filter/pan, so US$1800 is a no go.
Shop around for a cheaper price, maybe try an independent Jag workshop.
Old Aug 18, 2024 | 09:47 PM
Lothar52's Avatar
This service is ridiculous in the US
labor rates are crazy cause = maybe cause nobody wants to work hahaha
mmmjag
Sep 22, 2021 07:21 AM
robor
Jul 24, 2021 10:36 AM
Jag7
XE ( X760 )
Jun 20, 2018 01:08 PM
Jag7
Jun 7, 2018 07:20 AM
escape
XE ( X760 )
Aug 30, 2016 09:15 PM
