XF (X260) 2015 onwards
$500 at the dealer - What would you get?
Old Apr 5, 2026 | 12:30 PM
Lightweight's Avatar
Default $500 at the dealer - What would you get?
I have ended up with a $500 voucher to use at the dealer, I am thinking of trying to pick up some maintenance parts but what ones I am not sure.
The car has a new cooling system, new tensioners, new plugs so the basics are covered. I have air filters and oil filters already so what would be on your list?
Otherwise Lego Defender and other toys are inbound!
Old Apr 10, 2026 | 09:43 AM
2018XF25T's Avatar
It all depends on you whether you choose to use the $500 voucher at a later time. With thst you can buy a lot of things at the parts dept.
I have these (base part not included). You can use these either on the Car Seats
At the Drivers Seat:
https://parts.jaguarvirginiabeach.co...MaAvH9EALw_wcB
At the Passenger Seat:
https://parts.jaguarvirginiabeach.co...saAmFaEALw_wcB
Old Apr 11, 2026 | 08:13 PM
All $500 has to be spent in one transaction. Although it is my daily driver I dont have to suit up every day now.
I do need to get a couple of the stupidly expensive caps for the door pull handle screws, other than that I am thinking of what could be hard to find service items in the future. I did look up Diff oil on SNG, F-Ing hell that stuff is expensive! So is the Jaguar transmission oil so I am hoping my mechanic has equivalent at a better price or all $500 could go on just that!
Old Apr 12, 2026 | 08:23 AM
clubairth1's Avatar
Community Influencer
Diff oil and transmission fluid are not made by JLR. It will be much cheaper to get them somewhere else. I just find the JLR spec or search a bit on the forums for equivalent fluids.
Old Apr 13, 2026 | 03:38 AM
Haalex's Avatar
Diff oil is expensive but you only need one bottle. Motul Gear 300 will do the trick and is 1/3rd of the price.
Re: transmission, make sure to have a ZF specialist do it. They generally flush the cooler / torque converter on top of the regular gravity flush, which means a much larger portion of the oil is renewed (90% vs. about 50-60% with a gravity flush).
Old Apr 13, 2026 | 03:39 AM
Haalex's Avatar
Oh and back on the original topic, you can get metal shift paddles for a couple hundred $. They're useless but good looking.
Thunderjet Racing
Apr 23, 2023 04:07 PM
Clutch
Apr 24, 2022 01:21 PM
flatm3
XF (X260)
Feb 10, 2022 12:53 PM
escape
General Tech Help
Sep 8, 2016 06:02 AM
ken qv
Jan 13, 2012 03:03 PM
