AJ126 Rebuild Thread From Overheat Failure to 500600HP Build (Looking for Guidance
Ive looked into VAP a little bit and they seem to be one of the main names for this platform. Im still trying to keep the build somewhat balanced and reliable, but since the engine is out and apart, this is definitely the time to make decisions on pulleys, cooling, and supporting mods.
As far as a bigger IC/heat exchanger, yes, thats high on my list. Being in Vegas, Im more concerned with IAT control and heat soak than chasing a dyno number. Cooling has been one of my biggest focuses on this build because these cars already seem borderline in hot climates when driven hard.
Adding to the pulley bit and stating the obvious, if you are planning some performance upgrades, now is the time for pulleys! LOL.
As an FYI, I also had my SC ported by VAP (Jokerz is their partner for the porting) and am VERY happy with the power. From a VAP perspective, you are looking at about 450 BHP for the bottom pulley, 475 BHP for both pulleys and 550 BP if you also have it ported. The improvement from my original 340 BHP to the bottom pulley 450 was dramatic and a good midpoint. Unless you want to hunt BMWs, LOL
I am sure other folks have similar packages...
Last comment, I believe you are building the definitive AJ126 rebuild thread! Well done!
Ive been debating the pulley setup because I want the car to wake up, but I dont want to build something that becomes heat-soaked or unreliable right away. The numbers you listed make sense: bottom pulley alone being around that 450 BHP range sounds like a really good midpoint, especially for a street car in Vegas heat.
The ported supercharger is what really caught my attention. Since mine is already off the car, Ive been considering having the machine shop or a specialist handle the porting while everything is apart. I didnt know VAP used Jokerz for that, so thats good info. 550 BHP with both pulleys and a ported blower sounds strong, but Id want to make sure cooling, fuel, and tuning are all matched correctly before pushing it that far.
For now, Im leaning toward a pulley/tune setup with upgraded cooling, no E85, and keeping the build as reliable as I can. But I agree now is the time to do the pulleys if Im going to do them.
And I really appreciate the comment about the thread. Thats honestly what Im trying to do: document the AJ126 rebuild as thoroughly as possible because this platform has very little clear information compared to other engines. Even JLR answers seem to vary depending on who you ask.
hueyhoolihan
Apr 11, 2023 08:51 PM
sgaunce
Dec 15, 2020 12:23 PM
2000blackxkr
Jul 6, 2014 09:35 AM
