XF (X260) 2015 onwards
antifreeze
Old Nov 29, 2021 | 04:18 PM
CarsonCitySmith's Avatar
Default antifreeze
my 2016 XF owner's manual says to use Texaco XLC antifreeze. I find no discussion on the subject.
Does anyone know what other brands are compatible?
I think the aluminum motor is the concern?
Tx
P.
Old Nov 29, 2021 | 05:11 PM
Fraser Mitchell's Avatar
Is there no specification also shown ? There will be other antifreeze products available which will suit your car. I can't see that Texaco have a unique insight into what the Jaguar engines require !
Old Dec 10, 2021 | 11:43 AM
I ended up with Zerex Valvoline G40. "Recommended for Jaguar after 2014" according to the label. At NAPA. NAPA website says the same product in the pre mixed diluted form is not compatible for Jaguar. No clue why the one or the other. The product is pink, like what I find in my coolant reservoir after dealer only services on the vehicle.
Note: I have had this car for 2.5 years, 10,000 miles, and this is the first time I have ever added any fluids. 50 years of tinkering with cars is finally paying off.
Note: I think Valvoline and Texaco are the same and that both are owned by Chevron.
P.
Old Dec 12, 2021 | 10:05 PM
mleskovar's Avatar
Originally Posted by CarsonCitySmith
...10,000 miles, and this is the first time I have ever added any fluids.....
10K total? Keep an eye on the coolant level. It's a closed system and shouldn't lose enough to require topping up after 10K. Replacement isn't recommended until 10 yr./100K miles (?). 5 years 21K miles mine has remained stable.
Old Dec 12, 2021 | 11:08 PM
NBCat's Avatar
@CarsonCitySmith, after a cold-soak, preferably overnight, use a cooling system tester to pressurise the system to 1 bar and inspect for leaks. If the gauge on the pressure tester begins to drop, check the water pump and coolant outlet underneath the supercharger for leaks.
Old Dec 13, 2021 | 06:54 PM
Right. Good tip. I will watch the level and proceed if it drops again.
Tx
P.
LarkM
Nov 4, 2019 04:02 PM
bchallXF
XF (X260)
Mar 19, 2018 02:07 PM
Frank Lambert
XF (X260)
May 19, 2017 02:11 PM
angelng
XF (X260)
Jul 8, 2016 07:23 AM
Cambo
XF (X260)
Apr 28, 2015 07:15 PM
