XF (X260) 2015 onwards
Battery change
Old May 23, 2021 | 09:14 AM
ChrisG Jag lover's Avatar
Default Battery change
Hi all I have been getting intermittent error message’s I have checked the battery and from all the checks it looks like it is on the way out (original battery nearly 6 years old) car is XF MY2016 2.0 Diesel. Question is after disconnecting old and re-connecting the new do you need to enter any codes for immobiliser, radio, or any other systems such as in control etc.
Old May 23, 2021 | 12:31 PM
chrisjp's Avatar
I've disconnected the battery on my XE and then subsequently reconnected it, without the need to enter any codes. The only thing I had to do was to reset the one touch up and down windows. You do this for each window by operating the window down and then holding the switch in the down position for a few seconds. Then you do the same thing with the switch in the up position. That was all that was necessary so I guess the same must apply when replacing the battery with a new one.
Old May 23, 2021 | 12:55 PM
mleskovar's Avatar
There's talk on forums about having to "initialize" new batteries. As far as I can tell if you replace like with like (amps/cell type) you're good to go. If not same type then you run the risk of overcharging or undercharging. This all started in many newer cars when they went to so called "smart charging" that saves some battery charge space for recovering electricity when motor is in braking/no throttle mode. It supposedly increases mpg. I've tried to get definitive answers about it but failed. Anyone know for sure?
Old May 23, 2021 | 12:56 PM
Thanks for that chrisjp can’t imagine the XF & XE are that much different, battery change tomorrow it is then.
Old May 23, 2021 | 01:08 PM
Thanks meleskovar I am pretty sure it is the same, but will double check just to be on the safe side.
Old May 25, 2021 | 05:19 AM
Thanks all battery changed all faults gone,(after short drive) and nothing needed to be rest. All happy now.
Old May 25, 2021 | 06:44 AM
chrisjp's Avatar
Glad it worked OK. The dealerships (and JLR unfortunately) will try to tell you that a battery change is a job needing their "skilled technicians" but that is nonsense. The manual for my XE also says that battery charging requires the battery to be removed from the car which is also a job for the dealership. This again is nonsense - as long as you use an intelligent charger with AGM battery capability (eg a CTEK) you can charge it in place using the jump start connections under the bonnet/hood.
gr1pper
Jun 6, 2018 04:28 AM
leadfoot4
Mar 20, 2018 09:24 PM
Thermo
Sep 11, 2016 07:44 PM
MeatBag
Jun 20, 2016 02:39 PM
