XF (X260) 2015 onwards
Metallized front windshield
Old Jul 21, 2019 | 08:32 PM
orrlfrd's Avatar
Default Metallized front windshield
Anyone know if the windshield on a Jag 2018 Sportbrake is metallized? If it is a transponder on toll roads won't correctly.
Old Jul 22, 2019 | 08:42 AM
Porscheluxe's Avatar
Place your transponder in the dotted area near the mirror. My EZPASS has functioned perfectly since installation at the upper edge of the windshield in that area three years ago.
Old Jul 22, 2019 | 06:06 PM
orrlfrd's Avatar
Thanks for the answer. Porschelux. My dotted areas are to each side of the mirror, so I imagine that will work. Was your dotted area to the side of mirror or along bottom edge of mirror?
Old Jul 22, 2019 | 06:41 PM
It starts at the base of the plastic enclosure glued to the windshield, extends at an angle, to the roof.
Old Jul 22, 2019 | 06:48 PM
orrlfrd's Avatar
Thanks again. Just called the Fastrak here in S Calif, and was told they would have to send me a small "decal" to attach to the front headlight. They said not to put it on the metallized windshield, even in the area by mirror with dots, as it wouldn't work right. Asked about putting it on outside of front window, and was told that wouldn't work with the metallized windshield--must interfere somehow. Guess their technology is different, although he did say using the "old style" transponder that I have would work on the windshield, but that they were going to be phasing that out in near future, so everyone will have to switch over to the new way.
Old Dec 25, 2021 | 09:53 AM
Great's Avatar
Default I pass vs metallized windshield same prob.
Illinois i pass doesnt work if you put the transponder in rhe dotted area by mirror. Seems to not work even if i hold it by moonroof. Special transponder for license plate doesnt work inside car either and its such a clunky brick im not affixing to my frnt plate. No fix yet. Good luck
Old Dec 25, 2021 | 10:07 AM
orrlfrd's Avatar
Thanks! Have mine on the front light lens (it's very small) and is working fine here in CA.
Old Dec 27, 2021 | 07:07 AM
nicktee55's Avatar
The owner's handbook shows the locations where a transponder can be fitted. I know this shows 2019 XF but it's the same for 2018,
Old Dec 27, 2021 | 10:00 AM
orrlfrd's Avatar
Thanks so much for taking time to send the actual windshield image of where to place the toll stickers!
crashxx
Feb 15, 2021 08:18 AM
Terry099
Oct 29, 2020 07:42 PM
Dercent
Feb 9, 2018 09:52 AM
DaveC
Dec 2, 2012 01:18 PM
