XF (X260) 2015 onwards
Passenger tail light replacement
Old Sep 20, 2017 | 09:55 AM
michele4065's Avatar
Default Passenger tail light replacement
I need to replace the quarter panel-mounted passenger side tail light assembly. The LEDs are out, but the turn signal indicator and backup indicator still operate. It appears easy enough to do, but I'm wondering if I'll also need to replace the trunk-mounted portion as well. I'm hoping that when I replace the larger assembly the trunk-mounted light will come back on. Anyone have experience with this issue? Thanks!
