XF (X260) 2015 onwards
Performance difference between R-Sport and S
Old Aug 19, 2018 | 06:15 AM
JD Williams's Avatar
Default Performance difference between R-Sport and S
So other than the obvious 40HP, are the differences in R-Sport and S trim, mostly trim/cosmetic?
Is the 40 hp increase all tuning? I can see by just replacing intakes, installing smaller pulley and bolt on exhaust the 40 hp can be added.
Mostly curious. But interested to start a build. XF is a pretty unique car in my area, so potential for a unique build is high.
Old Aug 19, 2018 | 12:49 PM
mleskovar's Avatar
My understanding is the extra hp comes strictly from tuning, no special parts needed. My only concern with a build adding a lot of hp would be the split crankshaft..... haven't heard/read about a failure but split cranks are rare in motors (not unique to the 35t though).
Old Aug 20, 2018 | 12:10 PM
Whitefpace's Avatar
Hi,
the 40 hp difference between R and S trims is purely in the programming. VelocityAP and Eurotoys (as well as a few others) will take both models to 410-415 hp with just a tune flashed through the OBD port or over 445 hp (and a lot of extra mid range) when combined with a bigger crank pulley (and a new drive belt). The V6 already has a small diameter supercharger pulley, and changing it therefore yields just a few psi's of boost. Intakes and exhaust mods are much more for sound than for actual performance increases. The tune will add quite a bit of supercharger sound because it keeps the bypass valve inside the supercharger closed at WOT to maximize boost. In my experience it adds more sound than removing the engine cover, sound deadening liner under the hood, and replacing the original airfilters with aftermarket ones.
Old Aug 20, 2018 | 08:40 PM
Default Great info!
Thanks for the information. I wonder why it is de-tuned so much. You would think they would want to be competitive as possible in the 'Sporty Sedan' segment.
Makes me wonder if the rest of the drivetrain can hold it, or if the ZF transmission had issues at that level.
Old Aug 20, 2018 | 09:15 PM
mleskovar's Avatar
Originally Posted by JD Williams
.... You would think they would want to be competitive as possible in the 'Sporty Sedan' segment......
They are.
Old Aug 21, 2018 | 05:22 PM
Jay_Davis's Avatar
For 2018, only the S comes with the 6 cylinder supercharged engine. Everything else is a 4.
Old Aug 21, 2018 | 09:07 PM
Whitefpace's Avatar
No worries; the V6 and V8 use the same transmission and most of the driveline.
carzaddict
Jan 17, 2025 02:56 AM
jimforrest (uk)
General Tech Help
Mar 13, 2015 08:46 PM
wyxtype
Jan 16, 2014 11:07 AM
Mike007
Jul 21, 2013 07:29 PM
symbiote
XK120 XK140 XK150
Sep 22, 2007 10:00 AM
