XF (X260) 2015 onwards
XF V6 sound like an F Type V6
Old Aug 28, 2019 | 11:24 AM
selspeed's Avatar
Default XF V6 sound like an F Type V6
Why doesn't the XF sound like the F type? Intake, exhaust? Even if you put on the exhaust, will it work?
Old Sep 5, 2019 | 08:05 PM
OzXFR's Avatar
The F-Type exhaust is completely different and cannot be fitted to an XF without yuuuge expense, many thousands of dollars.
This is because the F-Type exhaust is a single large East-West muffler while the XF is the more normal pair of North-South mufflers.
It would be a nightmare trying to fit an F-Type exhaust to an X260 even if it was possible.
Another difference is the pops, bangs and crackles the F-Type exhaust makes on the over-run which are software controlled and it's probably not possible to reprogram the XF to do this. Tuning company Velocity AP make a range of after-market exhaust systems and mufflers for the F-Type and the XFR (X250) and they are able to program almost the same pops bangs and crackles into them with a tune, but they don't yet make exhaust systems for the X260.
It may be possible to fit a pair of F-Type SVR mufflers to an X260 as the SVR uses a pair of North-South mufflers.
But they cost a fortune, around $7,000 US each, and then there are all the brackets and other components on top of that, even if it could be done you wouldn't get any change out of $20,000 US.
IMHO your best bet is to wait and hope for VAP to make an exhaust system for the X260.
However in the meantime VAP offer a pulley and tune for the V6 in the X260 which from all reports changes the exhaust note to something approaching that of the F-Type, never mind the increase in power to 450 bhp!
Old Sep 17, 2019 | 09:19 PM
Stwsam's Avatar
VAP 100% can program pops and bangs. I used there tune on 2016 v6 was xf prestige.
as far as sound. On my xe-s I am running VAP tune and pulley and did the resonator delete. I had a 2016 v6-s. F type. My xe-s is quite similar in sound now even without an active exhaust. Xe is a bit more tenor but can absolutely howl. Imagine xf can go the same route.
Old Sep 19, 2019 | 06:34 PM
Bat One's Avatar
I have an XF-S Sportbrake. I did a rear muffler delate and I can tell you that it pus a smile on my face any time the tach goes above 3000 RPM! I'm not saying it sounds like a F-Type but, it's close!
Old Jun 18, 2020 | 11:53 AM
bfarrell's Avatar
Default Muffler delete
i tried that but the drone was unbearable
Old Jun 22, 2020 | 04:38 AM
hiltoncam's Avatar
The chassis of the two cars is totally different. The F-Type has a shorter body than the XF which would make it louder and raspier than the XF and Jaguar spend thousands of hours tuning the sound of the exhausts to get them just right. You will never get an XF to sound like an F-Type because they are simply two different cars built and designed in two different eras of Jaguar as well even though they share the same engine.
You could however straight pipe your XF to get a raspier sound, but just know that it will drone inside the car and become extremely irritating on long hauls.
Old Jul 4, 2020 | 04:45 AM
jared102's Avatar
Can I
Old Jul 4, 2020 | 04:51 AM
jared102's Avatar
Can I just overwrite a F-type program ?
Old Jul 4, 2020 | 06:23 PM
OzXFR's Avatar
I doubt it very much for a host of reasons I won't go in to, Cambo would know for sure.
Just get a VAP lower pulley and tune, this will achieve much the same result for "pops and crackles" as the F-Type tune and from all reports this will make it sound "almost" like an F-Type, as well as the added bonus of 70 more hp than even the F-Type S tune.
Old Jul 4, 2020 | 09:21 PM
jared102's Avatar
I just want the crackles,I am considering between the VAP and Vividracing.
I am not in a English speaking country,so difficult to pick the correct VAP program for me.
Old Jul 5, 2020 | 07:08 AM
bfarrell's Avatar
Default Pop and crackles
paramount performance sells a pop and crackle tune for your XF
b
Old Jul 5, 2020 | 09:30 AM
Stwsam's Avatar
Guys and gals. Pop over to the xe thread on resonator delete. It will transform your sound for about 200.00 usd at a quality muffler shop. Nothing is an f-type as I have had both, but the delete raises your volume wonderfully. There will be zero drone. Removing or changing cat backs will give you unwanted drone. Resonator delete keeps your car looking stock.
Adding VAP tune and pulley will make your car on par with the fastest sedans and the crackle and pop option is wicked and loud. I like it but it is intense and some may prefer the tune without pops which VAP will accommodate. trust me on this. I have used the tune in v6 ftype, xf and now xe. You can not get more real power and torque for the money anywhere.
Old Jul 6, 2020 | 11:07 PM
jared102's Avatar
b
i have seen paramount performance on YouTube,lots of x250 on it,no videos about x260 XF
Old Jul 6, 2020 | 11:11 PM
jared102's Avatar
b
I've found it on Paramount's website,Jaguar burble pop and bang tuning ...thx bro
Johnny Mayday
Jun 18, 2017 09:08 PM
Cherry_560sel
Nov 26, 2016 01:15 AM
doctordeuce
Mar 18, 2015 12:38 PM
Customgtrs
Apr 7, 2014 05:44 AM
