2010 Jaguar XF lock jammed and I can't access the boot via key manually or lock the d
Old Mar 15, 2017 | 08:58 PM
SaintCaesar's Avatar
Default 2010 Jaguar XF lock jammed and I can't access the boot via key manually or lock the d
2010 Jaguar XF Luxury...
Blaqjag
Old Mar 15, 2017 | 08:59 PM
Blaqjag
Old Mar 16, 2017 | 07:43 AM
pab's Avatar
pab
I believe that you are on the wrong list and need to post your question to the X250 group.
Old Mar 16, 2017 | 01:39 PM
Brutal's Avatar
Spray wd40 or other lube into the lock with the can straw stuck in the hole. Then work the key and try again. No one ever uses them so they tend to freeze up
Old Mar 17, 2017 | 06:14 AM
Blaqjag
Welcome to the forum SaintCaesar,
I've merged your two identical threads and moved your question from X260 to X250 forum. This is the place to post questions about your model.
Old Mar 21, 2017 | 12:04 PM
geekonaleash's Avatar
besides the boot lock being jammed, are the number plate lights still working? Had the issue on mine, and also a number plate bulb out, and had to replace the cable the connects the lock/number plate lights/reversing camera all up. Common issue on the older XF and the new cable is slightly longer by about an 1" to stop this happening.
