2010 Jaguar XFR fuel issue!
Old Jan 11, 2020 | 03:17 PM
DaBluedude's Avatar
Default 2010 Jaguar XFR fuel issue!
Hello all, new to the forums here, hoping someone can help me out.
My XFR decided to stop sending fuel randomly. I had been driving the car around town all day, then later at night while going out to dinner, the car started, idled for 10 seconds, then died. I tried to restart, and got only a small cough then it refused to start at all. I used my crappy bluetooth obd2 reader and did pull a code of P0627 from the system (as well as a pending low fuel pressure at rail code). I cleared the codes in hope it would reset, but it did not and the code is not coming up again. I noted that typically, whenever I open the driver door when approaching the vehicle, the fuel pump can be heard priming, this is NO longer the case!
I feel I must have an issue with either the Fuel pump itself, the FPDM (fuel pump driver module) or the fuel pump relay (from the shop manual it states that the FPDM is powered by a supply from the fuel pump relay in the RJB (rear Junction box)). I have checked the F25 fusein the rear junction box and it is fine, but I am at a loss to identify which relay is for the fuel pump (also can these relays be removed and replaced if they are faulty? or are they built in? If the relay is bad, should i be going straight to fuel pump, or are the FPDM known to be bad?
Could anyone shed some light on this situation for me before I loose my mind further. I have been scouring the internet for hours today trying to find an answer!
Thanks in advance!
Old Jan 11, 2020 | 03:47 PM
Bart Lenferink's Avatar
Hey Dude,
Had the same issue 6 months ago. Looks like your fuelpump is dying. Replaced the pump + Sender Unit. All is fine since then.
See attachment if you want to do it yourself.
Regards,
Bart
File Type: pdf
Old Jan 20, 2020 | 12:29 PM
clubairth1's Avatar
Community Influencer
Great instructions!!
You can use a universal tool to remove the lock ring. This will be much cheaper than the OTC tool.
Look for "Universal Fuel Tank Lock Ring Tool". They are about $25 on EBay.
The OTC tool is OTC-310-123 but a good bit more expensive. Usually about $60-$90.
Old Jan 22, 2020 | 04:21 AM
Bigg Will's Avatar
https://www.jaguarforums.com/forum/x...cement-220067/
The universal retaining ring tool may not work, I found a cheap OEM one that fit perfectly, make sure you got a 1/2 breaker bar handy because that retaining ring is on real tight.
Old Jan 23, 2020 | 10:51 AM
clubairth1's Avatar
Will can you say why it won't work? Or what I should look out for?
It looks exactly the same??
This is about $25 on EBay. Free shipping.
Fuel Tool
Old Jan 25, 2020 | 05:51 AM
정연옥's Avatar
Default .
Old Jan 25, 2020 | 05:52 AM
정연옥's Avatar
Default 윤활제 세척 후 정상작동
[QUOTE = 1 • I- ° ì~ ¥; 2,182,898]
[/ QUOTE]
scottpeterd
Jan 10, 2026 04:47 PM
SteveLeighton
38
Mar 25, 2018 02:10 PM
Thang Nguyen
May 1, 2017 07:37 AM
jkmspartan
XJ40 ( XJ81 )
Sep 3, 2013 09:03 PM
woodpuppy
XJ40 ( XJ81 )
Jun 1, 2009 10:52 PM
