2013 Jaguar XF Hazards Won't Shut Off
Old Mar 15, 2020 | 06:42 PM
Zach Thibault's Avatar
Default 2013 Jaguar XF Hazards Won't Shut Off
I drove for about 30 miles today before my Hazards came on, on there own, and wont go off. I shut the car off for about an hour and a half and then proceeded to have issues starting the vehicle. The brake pedal was very stiff and it didn't want to turn over. I finally pushed on the pedal as hard as possible and it started up. The lights still won't shut off though. I dont know what the issue could be.
Old Mar 15, 2020 | 08:25 PM
Update: the lights have gone off and come back on and gone off again in the past couple hours. I dont know if it's relevant but the radio was super laggy when I first got in the vehicle before leaving. And now the horn sounds different when I lock the vehicle. Before the issues I would press lock once and you'd here it click locked, then a second push you would here a horn arming the alarm I assume. Now I press to lock only once and it honks right away. I hope these aren't issues or signs of a larger electrical issue within the vehicle.
Old Mar 15, 2020 | 10:51 PM
litteredwithfaults's Avatar
Bizarre electronics behavior is usually an indicator of battery issues. That's right, a modern day car built and programmed without fault tolerance for low voltage. If the battery is more than 3 years old, replace it.
Old Mar 15, 2020 | 11:20 PM
Is there a way to check or test whether or not that is the issue before purchasing a battery?
Old Mar 25, 2020 | 09:16 PM
Swimref's Avatar
If you are still on the original battery it is well past needing replacement. Your symptoms are classic for a bad battery.
gabyyy
Jul 1, 2018 03:11 PM
Darron321
Jun 21, 2018 07:28 PM
marcoxpolo
Nov 20, 2016 02:45 PM
TMack
Nov 2, 2013 01:22 PM
Manny735
Jul 17, 2010 01:06 PM
