2013 SF 3.0 AWD SC with high idle at startup then operates normally
Old Nov 13, 2020 | 08:14 AM
RT13XF's Avatar
Default 2013 SF 3.0 AWD SC with high idle at startup then operates normally
I have a 2013 Jaguar XF 3.0 SC that started having an issue with the idle when first started (cold start). The issue is the idle fluctuates and then climbs up between 2000-3000RPM for a short duration then returns to normal idle (~750RPM) and operates normally after. This high idle condition does not always happen, but is frequent. When checking with OBD2 reader, I see the following trouble codes:
P2189 (too little fuel at idle, lean condition)
P2187 (too little fuel at idle, lean condition)
Below are some of the things I have checked:
Vacuum lines for leaks (found none)
MAF sensors (cleaned with CRC cleaner, didn't seem too dirty to begin with)
MAP sensor
Inspected the Throttle body (looks normal, not too much buildup)
Exhaust system (there may be a leak on the driver side exhaust pipe before the muffler at the joint, found water dripping at the location and black soot)
Added treatment to gas tank (didn't change the issue at all)
Has anyone experienced this issue, and is it something that can cause engine damage if not fixed now?
Thanks!
Old Nov 14, 2020 | 07:48 PM
VPinGA's Avatar
MAP sensor
Thanks!
I had similar symptoms on mine. Same engine. I tried everything and it turned out to be the PCV valve. My diaphragm was torn 50%. PITA to change with adult size hands but it can be done. The part it quite cheap on the net. You can search my posts or others for more details.
jim.jacoby
XF (X260)
Jul 30, 2024 07:50 PM
petemohr
Nov 12, 2020 11:53 AM
Spikepaga
Jul 19, 2017 03:53 PM
Rotorbug
Jun 4, 2012 11:07 AM
