380hp V6 F-Type
Exact same engine, so it's likely just software. Jag doesn't offer an upgrade tune for the XF 3.0 but there are third party tuners who do. (ETG, Eurocharged, etc.). With the right software and pulley upgrade you're likely to exceed the performance numbers of the F-Type.
Correct, the boost in this engine is controlled by the Bosch engine management controls. See post #10 here:
https://www.jaguarforums.com/forum/x...30/#post978606
The torque increase is very slight so these are marketing numbers. The real acceleration "advantage" the V6S has comes from the 10% shorter final drive, which includes a mechanical LSD and should fit our XF.
Wonder if it is compatible with the XF AWD and DSC software?
