Advice on buying a 2008 XF 2.7 with high mileage
Hi! I found a 2008 XF 2.7 with 230000km mileage, the car has been serviced and has passed the inspection to 2022. What warning signs should I be looking for when checking out/inspecting the car? I know the 3.0 motor is more reliable but how is the 2.7?
- The coolant tank leaking or sensor not working
- Turbo problem, where when engine cold under heavy acceleration for over 30sec hold foot down causes Restricted performance(limp mode)
- Crack in air intake pipe causes RP
- Fuel pump issue/indicator( shows less or more fuel on indicator)
- Boot not closing properly
- Burning/smoke smell in cabin when starting from cold.
- Window actuator
- Window actuator
Tbh, the car of that age, will have some problem now or later. Common problem will be ftom easy fix to more complicated ones.
- Window actuator
For the age of the car, there is a lot of variable to look out for. Best bet is to get someone who really knows to check or get a warranty from the dealer.
True that, The car has had over 7 owners, the last ones not owning it for more than a year, I think i will pass instead and try to find one with a honest service history.
