Battery Warning Light Stays On While Driving Please Help Thanks
Old Dec 8, 2022 | 10:58 PM
no1's Avatar
no1
Originally Posted by Madart
The car has a Battery Monitoring System which controls the alternator feed to the battery. Apparently when a new battery goes in this cannot relearn the new battery info itself and has to be reset, so a trip to the dealer may be in order.- try ringing a dealer and speak to the service manager to confirm this.
Check the wiring to the battery first- there is a thin wire to the monitoring system and if this is broken or worn it can cause the light.
is there suppose to be an inline fuse on that wire or is it just direct path to the positive terminal?
Old Dec 9, 2022 | 04:01 AM
John Williams's Avatar
It's a fuselink which is a length of lead which melts if there is a short, but won't blow with a surge which of course an ordinary fuse would. I would give the wire a tug to check if it has failed or test with a meter.
Old Dec 9, 2022 | 07:24 AM
clubairth1's Avatar
Community Influencer
The BMS will reset on it's own. It is not required to be reset when changing the battery. You can if you want to for sure.
See the first line from the attached service manual. It does it automatically from time to time.
File Type: pdf
Old Dec 9, 2022 | 12:51 PM
no1's Avatar
no1
New battery= calibrate bms
same battery= I would still calibrate bms
Replace bms= it will self calibrate, but I would still calibrate anyway just to be certain
Old Dec 9, 2022 | 12:56 PM
no1's Avatar
no1
thank you sir that would be what that hard bit in the line is then. I originally had thought the previous owner broke or cut that wire and soldered it back together but now see that's the section of lead
Clackavosticus
Jul 25, 2018 04:41 PM
DannyRobertHoward
Apr 5, 2018 03:15 PM
xtype62
Jul 13, 2016 07:12 AM
john501
Mar 2, 2015 01:28 PM
Rique
May 8, 2012 09:05 PM
