Buying used Jaguar wheels.
Old Aug 23, 2017 | 09:30 AM
harryf's Avatar
Default Buying used Jaguar wheels.
I'm planning on buying some used Jaguar wheels. They come with Jaguar TPMS sensors. They are F-types wheels and I am planning on putting them on my XF.
Do I need them reprogrammed?
Old Aug 23, 2017 | 06:07 PM
BlckCat's Avatar
F-types switched frequencies at some point in production so make sure it matches your stock ones. Search the forum to find the details.
Old Aug 25, 2017 | 08:22 PM
BritCars's Avatar
If you still have the 2012 XF in the USA then you should need 315MHz tpms. You'll need to check which F-Type ones you are getting
Assuming they are the right frequency they will auto program - although it can sometimes take a day or so before they register.
If you find they have aftermarket sensors I'd suggest changing for oem ones - the XF is very sensitive to aftermarket sensors and you can get spurious errors etc
More than anything else check the wheels are true and round - these larger diameter jag wheels seem to be very prone to bending...
