Center Cap
I presume you mean an X250 (the previous model of XF). The X260 was only launched last year. The X259 has a separate section in the forum
Wheel center caps are ~58-59mm. Lots of aftermarket ones on eBay from china. Very cheap although quality isn't great. But they work fine enough
I've moved your question from X260 to X250 forum. This is the place to post questions about your model.
Finding one the right size is not difficult. Finding one to match the others could be more challenging.
The cheap Chinese ones are perfectly OK, I had a set on each of my XFS and XFR for 18 months and they never faded, peeled or chipped at all. You can usually get a full set of four for much less than the cost of a single OEM one.
As mentioned by BritCars the sizes vary a little, and most of them are the slightly smaller size which fit rather loosely. Easily fixed though, just grab some electrical insulation tape and give it two winds around the retaining clips.
