Coolant hose rubber to metal connector 2013 XF
Old May 15, 2022 | 08:23 PM
hartmandm's Avatar
Default Coolant hose rubber to metal connector 2013 XF
2013 XF 3.0L supercharged. On the passenger (right) side, there is a coolant hard line that ends a bit shy of the air filter. The rubber hose that connects to the hard line connects to some odd plastic connector. I think it may have a slight leak. I haven't removed the part yet, but that plastic connector seems more likely to be the leak source than the rubber hose. The replacement hose (c2z4553) includes this plastic connector, but it seems like overkill to purchase a whole hose assembly for $60 or more once shipping is included. Wondering if these connectors can be purchased separately. Maybe these connectors have a replaceable o-ring?
Photo from my car:
A photo from another forum thread showing this connector on its hose:
Thanks,
Mike
Old May 16, 2022 | 11:31 AM
clubairth1's Avatar
Community Influencer
Maybe? I don't see any coolant stains in your picture?
Before tearing into anything I would wait until the car is cold and pressure test the coolant system.
Your leak could be elsewhere?
Old May 16, 2022 | 04:15 PM
hartmandm's Avatar
A little more background. I was fighting some leaks - a small plastic connector, then the thermostat housing, and I thought maybe the double o-ring joint between the upper and lower plastic crossover pipes. But with the removal and installation of that upper crossover pipe, I think the lower pipe cracked at its connection into the block. After pressure testing, there was a bunch of coolant sitting around the oil cooler. So I have pulled a ton of stuff apart, including removing the supercharger, so I could replace the lower plastic pipe that sits underneath the SC. I have replaced the rear plastic crossover pipe, even though it had no signs of leakage. It seemed like good preventative maintenance. Also, at this point, I can't be sure if the water pump, or the outlet pipe behind it might have been leaking, too. So I have replaced the water pump and the pipe behind it. I went with the URO aluminum version of the pipe. When I was threading the main serpentine belt back into place, I noticed the underside of that connection in my original post. It looks suspect to me.
Since the coolant system is currently drained and I already have everything apart, I am more inclined to address that connector now rather waiting until I re-fill the system and then pressure test.
Thanks,
Mike
Old May 16, 2022 | 04:35 PM
IanXF's Avatar
I changed all the hoses on my 2012 reason that same connector crumbled into bits when i was removing it yours is a 13 I think its time to do all the plastic and hose connectors so you don't have a failure when your out on the road
Old May 17, 2022 | 08:08 AM
clubairth1's Avatar
Where did you get the Euro Al. version? I had them marked on EBay but that seems to have died. I got one for me but I have been recommending it for others but I can't find it listed anymore?
Don't know if you have seen this yet? But we now have after market Aluminum pipes to replace the terrible plastic ones!
Al. Cooling Pipes
Old May 17, 2022 | 11:11 AM
hartmandm's Avatar
Aluminum versions of those pipes! I don't have it all back together yet, so really tempting to go with those. Thanks so much for providing that.
The aluminum outlet pipe that connects to the backside of the water pump is URO LR028136PRM. I got mine from Rock Auto. An internet search comes back with a bunch of other seller options for the part number.
Mike
Old May 18, 2022 | 08:32 AM
clubairth1's Avatar
Excellent Mike! Just what I was looking for. Surprised URO used the LR part number?
I see them all over EBay now too.
Ophitoxaemia
Oct 11, 2024 06:38 AM
Jon89
Jan 3, 2021 04:23 PM
Blue_XJ8
Mar 12, 2018 08:04 PM
jagdohrman
Jul 1, 2017 11:36 AM
srpope80
Jan 26, 2012 04:02 PM
