Coolant Leak
Old Feb 12, 2024 | 01:02 PM
Tra5.0sc's Avatar
Good question and I don't think a failing thermostat sets any codes?
You can read the actual engine temperature in real time? I use the custom PID pack and Torque Pro.
We don't have any temperature numbers and that might help here?
Yes, monitor all the temps through the OBD port with a wireless device. Oil, Coolant, and Boost psi. Just did another block test and it passed
Old Feb 12, 2024 | 06:38 PM
Six Rotors's Avatar
What kind of oil temperatures do you see when your coolant temperature is 210F and your tank spews coolant?
Old Feb 12, 2024 | 09:15 PM
Tra5.0sc's Avatar
Originally Posted by Six Rotors
What kind of oil temperatures do you see when your coolQuick Replyant temperature is 210F and your tank spews coolant?
Around the same temp
Old Feb 12, 2024 | 09:27 PM
Tra5.0sc's Avatar
Could a bad car battery cause the issue ?
Old Feb 12, 2024 | 09:58 PM
Six Rotors's Avatar
Regarding oil temperature, assuming your engine is fully up to temperature your oil temperature should read at least 30F higher than coolant, and if you are pushing hard the difference could be higher than that. Below is picture of my temperature monitor showing over 40F difference.
I can't see how a bad battery could cause the problem you described. Do have a copy of the Service Manual for your car? Did you follow the procedure for refilling the cooling system?
Engine coolant is lower left, engine idling after run
Old Feb 13, 2024 | 08:32 AM
clubairth1's Avatar
Community Influencer
Sweet little gauge install right there!
Old Feb 13, 2024 | 08:51 PM
Tra5.0sc's Avatar
Thanks for all the help. Pulled cylinder 4 spark plug out and found rust at the tip. Planning to pull bank 2 cylinder head off.
Old Feb 13, 2024 | 09:54 PM
  #28
xalty's Avatar
pressurize it overnight stick a camera in the holes see if there’s coolant in there.
if it is, buy yourself some time and run it with the cap loose, 5l head job is a mission from hell and needs a full machine shop on hand
mpasiuk
24
Mar 14, 2022 10:12 PM
Graham 2002
Jan 14, 2018 04:33 PM
Jon89
Dec 1, 2014 11:41 AM
MParkz
Jul 9, 2013 12:11 AM
PBNJ
Dec 9, 2010 01:50 AM
