Coolant Level Low Alert???
#41
#42
Received 2,184 Likes
#43
#45
Although I hate too, I have to agree with Lotus on this one, Spend the $$$ and just replace the tank, as he say's the plastics are consumable on these cars.And as Brutal has said rigging something like this is just crazy on an XF. $100 is still WAAAY cheaper than an engine, it only takes about an hour to do.
#46
#49
The sensor is built into the reservoir if I am correct. There are no external sensors. I checked and did see that my coolant was really low. I did not see any leaks anywhere so where did all the coolant go??
#50
https://www.sngbarratt.com/us/#!/Eng...6-49c970e5e030
If this was the first check then the level may have adjusted itself
Maybe fill to level and watch daily
If you added fluid did the low level light go off?
#51
There is an external sensor, some tanks are supplied with it installed
#52
If you changed the tank, topped the fluid up, drove it then the first time you checked it the fluid was low, this can happen.
If you then top the fluid up and it still keeps dropping then obviously try to see where it is going, otherwise it should hold the level now
I would check the tank daily until you can see if it is holding the level of fluid rather than waiting for a sensor to show anything
#53
The tank has an inbuilt sensor and an external sensor, possibly the plug you mention
Hi Santer,,
Yes I replaced my original with a new oem tank. I did top it off and am monitoring it daily now. You said that the fluid can be low the first time after a fluid top off. Why is that?
#55
#56
The coolant systems don't use up coolant. If you have less coolant than before, you have a leak.
#57
#59
Remove the underside "belly pan", and see if there's any liquid contained in it. If so, then start looking for any sign of liquid dripping from one of the coolant hoses, radiator, etc. If there's no evidence of liquid, then you have an inordinate amount of air in the cooling system. When you replaced the reservoir, did you run the engine, with the heater on at max temperature setting, and the radiator cap off, for at least 10-15 minutes?
