creaking brakes
Old Apr 9, 2022 | 06:55 AM
prolepsis's Avatar
Default creaking brakes
Any ideas what might be causing this creaking on the front left brake (watch the attached the video)? The noise occurs on both press and release of the brake. I've replaced the pads and spring, and later the disc, and both times the sound stopped but returned after a short time. It seems to get louder with time and more use.
creaking.mov
Old Apr 9, 2022 | 03:58 PM
VicVegas84's Avatar
Caliper piston in rough shape? slide pin not greased up well? What did it look like when you replaced the pads? Did you grease up the slide pins?
Old Apr 10, 2022 | 10:02 AM
prolepsis's Avatar
Yep. The mechanic even polished the pins.
usmc1211
Dec 11, 2012 10:58 AM
flyrr100
Nov 27, 2012 08:06 AM
nothinbutmoney21
Aug 27, 2012 07:19 AM
tallblondeguy
Mar 12, 2008 02:52 PM
