Driver's seat = ECU?
Old Aug 9, 2017 | 10:34 PM
Lafe's Avatar
Default Driver's seat = ECU?
I have a 2011 Jaguar XF. If the ECU/ECM is not programmed for the vehicle yet, will the Driver's seat not adjust? I can get the passenger's seat to move and adjust. It is certainly a pain to get the module out when the power seat does not work. Just sayin'...
Thanks in advance.
Old Aug 9, 2017 | 11:29 PM
JBzXJ40's Avatar
I'm assuming you're referring to Driver Seat Module, then yes. It will need to be programmed before you can move it.
Old Aug 10, 2017 | 07:42 PM
Lafe's Avatar
So, it sounds like I have went to a lot of trouble to take that module out for absolutely no reason. Ugh! I guess I'll have even more fun putting it back in now. I bought the Jag with a flood damaged title. I have to have the ECM programmed for a lot of the other stuff to work. The unlock button on the key fob put all the windows down, and they won't go back up now. I am assuming that is also an ECM thing?
Old Aug 10, 2017 | 08:20 PM
OzXFR's Avatar
All the windows down at once is called "global open" and it's done by holding down the unlock button on the fob for a few seconds.
So maybe the unlock button on the fob got stuck down?
Old Aug 10, 2017 | 08:23 PM
JBzXJ40's Avatar
The window should be within the door module software, not with the seat module.
Is the Driver Seat Module the only thing you've changed?
What else isn't working?
