E diff fault code 2010 xfr???help
Old Oct 29, 2021 | 06:03 PM
Adventurous x's Avatar
Default E diff fault code 2010 xfr???help
So I'm driving and I'm getting to see differential system fault and then I went home and stopped the car and then I drove it again and it didn't go on I guess it's something that's happening sporadically does anyone know if I should have this checked out at the dealer because if there's no code it won't show up on their system or is this something I should worry about please let me know I'm under warranty so I want to get it fixed
Old Oct 29, 2021 | 06:55 PM
BritCars's Avatar
How is your battery. That and gearbox fault are common spurious errors when battery is failing.
Old Oct 30, 2021 | 03:18 PM
clubairth1's Avatar
Community Influencer
Don't know but will suggest to change the rear diff oil ASAP. It's easy and for sure it needs to be changed by now. It might even be low on fluid?
Old Oct 30, 2021 | 03:35 PM
kansanbrit's Avatar
Mine did that for a while, I would try cleaning the electrical connector.
Old Mar 4, 2024 | 05:03 PM
Sulaimman alrawahi's Avatar
Default E diff
So what was the fix ? 😅
Old Mar 6, 2024 | 09:53 PM
bmcinsd's Avatar
Yes!!! I was paranoid that it was a failing rear diff… grinding, nocking… replaced the battery and it went away.
sufi_786
Mar 26, 2023 10:01 AM
Terry Keeling
Jun 30, 2017 10:48 AM
kbeachy
Feb 14, 2014 07:07 AM
jagman96
Aug 11, 2010 10:35 PM
