E85 or No
Old Nov 9, 2021 | 04:39 PM
Oxidizer2k's Avatar
I would love to be able to use that kit on my 2010 xfr.
Old Nov 10, 2021 | 09:13 AM
DeviLSh's Avatar
that ProEFi sensor looks like an oem part with a sticker on the top haha.
I dont recall seeing that sensor near my brake fluid container, and my gas cap is black. Darn, im part of the 99% club!
Old Nov 13, 2021 | 11:05 AM
clubairth1's Avatar
Community Influencer
Yes me too. I still have not checked my car but pretty sure it does NOT have it.
Old Feb 9, 2022 | 09:09 PM
Exhauat Note Channel's Avatar
I just scooped up a 2015 5.0 SC, and yes it has the yellow gas cap. I haven't put E85 in it yet though. I have plenty of stations near me that have it though. I'm currently running it to empty and will fill it with E85 to see if it runs any different or picks up some gains.
Old Feb 10, 2022 | 08:43 AM
clubairth1's Avatar
Man you got a Unicorn there!!
As you know we really don't have much info on these rare cars. I wish I could add E85 to my XJR. We have found the flex fuel sensor but I am still confused on exactly what needs to be added to make the car E85 compatible.
Let us know how you like it.
Old Feb 10, 2022 | 08:59 AM
Default E85 or premium acceptable
Here she is. About to get her first bath.
First bath!
I'm Flexin on ya'll...lol
Old Feb 10, 2022 | 10:15 AM
clubairth1's Avatar
Does your car have both AUX radiators installed on the sides?
Usually the drivers side has a blanking plate installed behind the grille if not.
That's another very rare option.
Old Feb 10, 2022 | 10:25 AM
  #28
If you meean the lower grill open on both sides then yes, it has radiators on both sides.
Driver side
Passengers side
Old Feb 10, 2022 | 01:37 PM
XJ8JR's Avatar
That is rare. I have the E85 but not the dual radiators.
Old Mar 24, 2022 | 06:15 AM
  #30
Tetedampoule's Avatar
Hello,
Personally, I drive 50% E85 and 50% E10 with my 2012 XF V8 (385hp)!
No starting problems, no engine light problems, and the kitten is purring as usual!
Old Mar 24, 2022 | 10:32 AM
  #31
clubairth1's Avatar
Can you fill in any details? Is the car stock? What was done so you can run that percentage of Alcohol?
Old Mar 24, 2022 | 01:22 PM
  #32
In fact, nothing has been done... No change!
I go to the pump, and I put, roughly, 50% E10 and 50% E85
I inquired to pass the beautiful 100% E85 with a box "flexfull" approved in France: 1290€
Wihout the "fuelbox", I found a company that reprogrammed the ECU for me: 400€
So no technical change (hoses or others)
So technically no problem for the car.
The only consequence, if the percentages are exceeded too much, the engine light will come on because it will find a difference in combustion. You just have to add the E10 and the light goes out!
And if the temperatures are too low, the Jaguar may need more time to start...
I have a friend who had a Range Rover V8 and drove 100% in the summer...
The idea is to gradually increase the percentage of E85.
A slight overconsumption can happen, but I don't... As before!
I've done this before with an MX5 (Mazda), Yaris and Aygo (Toyota) and even a 2000 Peugeot 206 with 160,000 miles. for the Peugeot, I stay at 30% because it is very old...
Old Mar 24, 2022 | 07:35 PM
  #33
insomniac_driver's Avatar
Sorry everyone for lacking in my research, was tackling other things and fixing other problems with my XF 5.0 SC, as for the information regarding the flex fuel sensor, thats great work. So my question is, do the cars that have a black gas cap already have a flex fuel sensor in it? I would need to check the exact location, a pic of an XF with it would be helpful so I know exactly where to look. If the answer is no, then the following question would be is there already the wiring to make it plug and play? Something that I would find out at the same time as I dissect that area of the car.
That ProEFI flex fuel sensor kit is enticing, cheap enough where it may be worth it, but that means they got it for much cheaper and are making a profit, maybe its just a ford sensor after all! But they do not mention anything about reprogramming by quickly browsing the link, so maybe it is simply plug and play for us jag owners if this is all that is needed for the RR owners! Did someone ask them if that sensor works for Jaguar as well? Found this OEM sensor on this website for only $75!
For Land Rover Jaguar hybrid fuel sensor flex fuel sensor OEM CPLA9C086AA - xiuyan sensor main various automobile import original sensor,Pressure sensor, air pressure switch, oil pressure sensor, crankshaft position sensor, camshaft position sensor
IF software is still a problem, is there is a way to easily change it via the SDD under the CCF (Car Configuration File) whether this is under a dealer computer or the developer version. I would be comfortable dong this, but I do not have an SDD and have not felt confident enough to make that purchase without giving myself a guarantee it would be useful. I also hear the back and forth regarding a mongoose cable being aftermarket and bricking the car. Since this is my daily im too concerned to tackle that without some help or instruction. (I also desperately want to add adaptive cruise to my car and just read a couple forums on people completing it successfully and adding Queue assist which would make this an insanely phenomenal vehicle and make me super happy) Another software famous in the RR world is the IID Tool form GAP Diagnostic, I am communicating with them regarding the ACC system I'm interested as its more of a guarantee than the SDD system, but as mentioned on another forum as well as this one, for every 1000 ranges they get, 1 jag will make a request, thus development on the jag side is more uncommon. Still in communication with them so we will see if I make any further developments...
To back up @Tetedampoule, as I mentioned before, I too have thrown 5+ gallons of e85 mixed with the remainder of the tank for 93 octane, especially on hotter days as ethanol runs cooler, might try 50/50 and see what happens. the car did immediately start to burble more, but I will say I saw a slight decrease in mpg as the government rates this car on e85 at 9 in the city, 16 mpg on the highway (15/23 normally) So then that brings up the question of whether all our cars are secretly just flex tuned and jaguar had some regulation or restriction to make it different.
@Exhauat Note Channel, I am absolutely jealous, a white '15 5.0 SC with flex fuel? what a beauty congrats! I did not know about the dual radiators on each side, I believe my car has it as I remember when making my whiskers black, maybe that is why I don't feel much heat soak when my completely black on black jag drives in 90+ degrees. Both grilles are open so thats good news for me!
Old Mar 24, 2022 | 07:41 PM
  #34
Insomniac_driver I was lucky to get this car. My customer traded it in and I immediately scooped it up. Didn't even think twice. I do like that all murdered out look you got too.
cars been great. Haven't done any mods just yet, but they'll be coming soon. I'm pretty sure I'll upload vlogs on my YouTube channel once I do.
Old Mar 24, 2022 | 07:47 PM
  #35
I've been meaning to do that, just never got around to it and the recording difficulties, all I did was exhaust and intakes, going on almost two years with the car and want to do these retrofits, possibly a tune to unleash over 600+ hp but just been so happy with the car in terms of how its behaved (other than the pothole nonsense up here in the northeast)
Old Mar 24, 2022 | 07:48 PM
  #36
Also I believe those are the OEM XFR-S wheels you have on your car @Exhaust Note Channel, which means your wheels are fully forged....you really scored BIGTIME.
Old Mar 24, 2022 | 07:49 PM
  #37
What did you do to the exhaust? I been thinking about a xpipe to replace the front resonator and getting valve control mufflers. I got these beautiful Florida roads for smooth sailing.
Old Mar 24, 2022 | 08:08 PM
  #38
Similar thing, x pipe to replace front resonator and straight up muffler delete, never looked back, drone on the highway after two years got slightly annoying but my music is too loud for me to care. You won't regret it.
Old Mar 25, 2022 | 11:53 AM
  #39
clubairth1's Avatar
We don't have great info yet BUT I think the flex fuel sensor on the XF's is mounted on the firewall somewhat close to the brake MC stuff. If anyone happens to see it (Pictures of the sensor are posted up thread) it would be a big help to take a picture and post back to this thread for everyone's benefit.
Old Jul 15, 2022 | 12:29 AM
  #40
boostedxf's Avatar
Originally Posted by deafknot1
Has anyone ran E85 instead of premium regularly. I have a 2014 XF SC V8 and gas prices are killing me lol. I was going to run E85 instead since its cheaper but I didn't know if there would be issues. Thanks for all the help guys!
https://www.magnumtuning.com/en/deta...ler/jaguar/xfr
Anyone ever hear of this? was looking into this subject a little while ago and came across this. I would sure love to get as much out of the car as I can. Sorta running out of stuff to do for the performance so this would be awesome if it actually worked. May just try it out.
