ECU PROBLOM jaguar 2013 4 cylinder
Old Jun 9, 2021 | 09:08 AM
Ahmed Ben Ammar's Avatar
Default ECU PROBLOM jaguar 2013 4 cylinder
JAGUAR 2013 xf 4 cylinder.
Hello . Please i have jaquar XF 4 CYLINDER 2013 .
this car started working 3 cylinder .i think from the begging is Coyle..i changed the Coyle but still not working..so u chsnge The ECU and i program it the ECU .. now the car just work minute then now speed ...when i pute the old ECU the car worke and speed work but 3 CYLINDER... so somwhen have IDEA about this ..thank you
Old Jun 9, 2021 | 10:18 AM
Welcome to the forums Ahmed,
I have deleted your other versions of this same question from XJS forum and other threads here in X250 forum.
Have you had the error codes read? I expect you can hear the engine is only running on 3 cylinders but the error codes will confirm which cylinder is the problem and could also help identify the possible causes.
Old Jun 9, 2021 | 11:32 AM
no errors code showing .just the first cylinder not working ..but when i changed the ECU .. the car working but after 15 minute the speed not working ??
Old Jun 17, 2021 | 03:26 AM
0n0t0le's Avatar
make compression test.
meanymean7
XF (X260)
Apr 5, 2019 05:37 PM
Masta Jaggins
XJ40 ( XJ81 )
Sep 8, 2018 12:38 PM
Highlander64
Nov 30, 2012 07:30 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
