Engine fan
Old Jun 18, 2023 | 05:23 AM
monkey magic's Avatar
Default Engine fan
My Xf 250 2014 diesel engine fan is on constant and wont turn off .
Old Jun 18, 2023 | 01:18 PM
mateuszyo's Avatar
I had a case like this a few years ago with the XF. do you have any error codes? in my case, replacing the fan did not help. turned out to be a faulty motor controller. buying a second controller + coding solved the problem. you should first read the error codes, later replace the fan
Old Jun 18, 2023 | 03:32 PM
Default Engine fan
Therse no codes and everything is working fine . I had three garages do diagnostics one was just an auto electrians and yhey said it leads to the fan being the fault .£685 for a new fan and £300 labour cist to fix it .
Enrique Meza
Jul 24, 2023 06:46 PM
jcb-memphis
Jan 22, 2023 12:55 PM
jarrod manzi
General Tech Help
Nov 6, 2022 02:11 PM
ednoon
Apr 7, 2021 11:09 AM
revski666
Jul 1, 2016 09:58 PM
