Error codes, any help is appreciated!
Old May 29, 2017 | 03:41 PM
allencass's Avatar
Default Error codes, any help is appreciated!
Hi all,
I'm getting a couple of error codes from my 2011 V8 NA.
I've read what i could find, which is minimal, so hoping somebody has an answer or suggestion. Using a code reader and Torque Pro, i got the following:
P0106
P0430
I am not a mechanic by any means and wonder if these will require a trip to one.
Thanks in Advance,
Allen
Attached Thumbnails Error codes, any help is appreciated!-screenshot_20170529-161454.png   Error codes, any help is appreciated!-screenshot_20170529-162056.png
Old May 29, 2017 | 10:29 PM
Mr Sharky's Avatar
I have nearly the exact car that you have but mine is black. Based on those codes it could be a number of things with the simpilest being a faulty O2 sensor. But I think that you ought to bring it to a mechanic with the SDD computer so that you can find out for sure without spending lots of money changing out parts until you find the real problem.
Old May 30, 2017 | 06:37 AM
allencass's Avatar
Thanks. I'll do that. Luckily I recently found an independent garage, so hopefully they can help me out. I should mention that I'm not noticing any perormance related issues. Just dropped her off this morning to get a spoiler and new black grille put on, so it will be a little before I can. I will update the post once I have any more information
