Fault code u101 (faulty transmission control module)
Old Nov 17, 2020 | 02:08 PM
raggeew's Avatar
Default Fault code u101 (faulty transmission control module)
Hello!
In my XF 3.0DS gearbox fault messages are showing sometimes randomly. Ive got the fault code u101 which means faulty connection to the tcm (transmission control module). Does someone know where I can find the tcm? Thinking of its maybe som moisture causing the fault codes?
Regards Rasmus
Old Nov 17, 2020 | 09:08 PM
BritCars's Avatar
How is your battery? I've seen the gearbox fault flash up before when battery is dying...
Old Nov 18, 2020 | 11:25 AM
raggeew's Avatar
Its a pretty new battery, shouldnt be the issue.
Old Nov 18, 2020 | 07:24 PM
BritCars's Avatar
Well charged? Some people are driving much less at the moment and battery gets depleted and starts to give errors. (Ask how I know - didn't run my XF for a few wks and hadn't put it on the tender. So It wouldn't crank at the weekend...)
Old Nov 19, 2020 | 10:21 AM
Rummy636's Avatar
Originally Posted by raggeew
Hello!
Regards Rasmus
TCM is in the transmission if i remember correctly. There's a plug on the back of the trans for power and communication wires.
Killawatt
Dec 23, 2022 07:30 PM
nigelharley
Feb 13, 2015 05:50 AM
matthew.r
Jul 7, 2014 11:32 AM
jagman96
Aug 11, 2010 10:35 PM
ItalianXtype
Mar 26, 2008 06:36 PM
