Fuel pump failure- is this a common one?
Old Jul 14, 2021 | 07:29 PM
POD XF's Avatar
Default Fuel pump failure- is this a common one?
The SV8 has been laid up for a fortnight waiting for a new fuel pump to arrive from the UK- finally got the new pump in yesterday and happily the Jag is back on the road instead of in the shed where it has spent altogether too much of the 18 months I have owned it.
Upon removal of the failed pump, the fault is immediately apparent; one of the power wires that has a spade connector from the flange, has been getting hot. The insulation on the wire itself is melted near the spade connector, there is heat discolouration around the base of the spade terminal on the pump body but, oddly, the spade connector itself is a VERY loose fit. I am wondering if this loose terminal has been producing heat in there since new and eventually led to this failure. The wire was disconnected when I removed the pump but this could easily happen during the removal of the top flange so no way of knowing if the failure was just that the wire had finally come off.
Old Jul 15, 2021 | 02:02 AM
John Williams's Avatar
I seem to recall some sort of technical paper on this, I think you can get a repair loom??
Old Jul 15, 2021 | 02:14 AM
Bit here about it........https://www.jaginfo.org/threads/xf-f.../#post-2848702
Old Jul 15, 2021 | 11:26 PM
POD XF's Avatar
Originally Posted by John Williams
Thanks, I had read on here something about a recall- this is on later vehicles than mine though. The description of the problem is just the same though- the car just cut out without warning and coasted o a stop, no fault codes or error messages. I had only just filled up and was worried I had bought dirty fuel, had visons of the whole fuel system having to be replaced. $600 and a 2-week wait for a new pump was bad enough.
Ziffo
Oct 24, 2024 10:14 AM
scottpeterd
Jun 24, 2021 09:20 AM
marktmv
May 11, 2016 10:32 AM
Wascator
May 11, 2013 03:23 PM
