Fuel rail bleeder valve
Subscribe
Jun 12, 2022 | 07:48 AM
Where is the fuel rail bleeder valve on the 2011 XF 5.0?
Reply 0
Jun 13, 2022 | 10:14 AM
That engine is a DI engine and the fuel pressure are very high and dangerously so!
I don't know any way to bleed the pressure off other than loosening a fuel pipe connection to let it bleed down.
Just be careful as the pressures are many times higher than the older style port injection engines.
Is there a reason you want to bleed it down?
Reply 0
Jun 13, 2022 | 10:17 AM
Quote: That engine is a DI engine and the fuel pressure are very high and dangerously so!
I just want to make sure there’s no air in the system. I would imagine if there were any it would exit through the injectors. I’ve recently replaced the high pressure fuel pumps and 4 injectors.
Reply 0
Jun 14, 2022 | 08:26 AM
That's a good point and I have not heard about air problems in the fuel lines on these DI engines. It's a very common problem on older Diesels and you did have to crack the fuel lines to bleed the air out.
Reply 0
Subscribe
Currently Active Users (1)
