Fuel rail shraeder valve
Old Oct 8, 2017 | 02:27 PM
Cherry_560sel's Avatar
Default Fuel rail shraeder valve
Fellas....where would be the best place to install a shraeder valve in our fuel rail system? I am looking for at some direct port spray kits, and I am having trouble finding a good fuel source location. Any help would be much appreciated?
Old Oct 8, 2017 | 04:07 PM
Bigg Will's Avatar
Seems to me you'd have to T in BEFORE the high pressure pumps, remember 5.0L cars are DIRECT INJECTED, so tapping into the 2100psi+ fuel rail is just NOT an option. You might pose this NOS question to the GM direct injected LT1 guys (Vette, Camaro, Truck).
Old Oct 8, 2017 | 04:20 PM
That is what I was worried about! I am in the 3.0L, but still have 2000+ of psi in the fuel rail.
Old Oct 8, 2017 | 11:42 PM
Since using the supplied T- fitting for the fuel is looking like the only option, where exactly is that line located?
I am actually thinking of going with a direct port system eventually. The only reason for this is that when I had the intake and S/C off for the coolant crossover pipe replacement, I got a look at those valves and they were nasty. planning on getting them walnut shelled and having a direct port wet kit installed so I can spray the top of those valves occasionally...just so they stay clean...hehehee...I also want to avoid delamination of the coating on the S/C impellers but I think they will hold for a while.
The fitment issues can be dealt with if I am smart about it and the SS tubing will look totally sic....for now I will stick with the single nozzle wet kit.....as soon as I can find info about that fuel supply line
Old Oct 9, 2017 | 12:10 AM
OzXFR's Avatar
Cherry,
Here is a link to a detailed PDF about the AJ133 V8 which might help you as the fuel injection system on your AJ126 V6 should be pretty much identical: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
Old Oct 9, 2017 | 12:23 AM
Thanks Oz...it's torture waiting for WON to get back to me regarding the best place to T into the line !!!
Old Oct 9, 2017 | 12:38 AM
Found it!!!! Thanks Oz !!!
